Timing belts parts needed when swaping a b16b or a ??
  • Thread starter Thread starter loverboy
loverboy
Hey !
Im collecting the lasts parts 4 my b16b or a swap into a ek4 coupe (d16y8 engine).
I would like to know what r the seals and timing parts ill need 4 the swap? i know about this :
1. b16b/a Timing belt .
2. tensioner (PN 14510-P30-003).
3. 2 cam seals.
4. cranck seal
5. water pump. 6. civic si (b16a2) or del sol vtec (b16a3)radiator hoses kit.
is there any more parts related to the timing parts ill need (besides the other belts like ac,p/s,alt..)?
Do i nee to buy a new shaft/axles seals too ? if i do how many seals there is? (including the intermediate shaft seal if there is one).
What is a Idler ?
Thanks !!
The tranny seals are:
91205-PC9-711 - Right Axle Seal
91205-PL3-A01 - Left Axle Seal
91215-689-013 - Shift Shaft Seal
91214-PLE-003 - Rear Main Seal
Definitely a clutch kit and flywheel.
Always good to check the valve clearance.
All fresh fluids. I would do an oil change, let the car run for 30 minutes, then drain it and fill it again with fresh oil. I hope that helps.
Ok !
I bought for the swap a integra 94-01 shafts (including intermediate shaft) will those seals will fit ??
Will this seals will fit the b18c (ITR) trans too ??
Thanks.
