TPS adjustment, jumps around?
  • Thread starter Thread starter cheese9988
  • Replies Replies 3
  • Views Views 838
cheese9988
VIP
I finally found the thread that tells me how to adjust it, so I tried adjusting it today. Its a working tps sensor I got off another motor. The problem is that if I rotate it it stays <100mV and then at one point it jumps up to 4.5V. But if I move the throttle, It will gradually go up and down like normal. What would cause this?
Well after playing with the sensor for awhile I finally figured out that the thing had to be placed in there just right for it to work proporly. I had to kinda take it out, place it in there to the side so that the holes did not line up, and then rotate it till they lined up, and then adjusted it from there. After that the check engine light shut off, and the engine runs much more smoothly, and for some reason its not as loud, but I am not sure why this would affect that. The engine idles much better as well.
