tranny plug?
jbeck
So im alomost done with my first swap. I have a 90' dx. I am putting in a b16a, obdo. The wiring is just about done, my question is: what is the plug on top of the tranny, its grey and square-like. I am using my dx harness and adding everything for vtec and o2 sensor and knock sensor, ect. there are no other plugs like the one on the tranny. I cant find anything about this anywhere. Thanks for any info.
for what?
thanks for the reply, its much appreciated!
where is the sensor located? some B-series transmissions used an electronic VSS sender, kind of like #9 in the attached picture - if you have the electronic VSS, you need to remove it and replace it with the cable sender from your DX transmission
i think that is it. Ill check tom. Thanks alot! If it is, does the cable sender just bolt in? Remember, my first swap! lol.
Thanks again.
yes, just remove the one from the B16 transmission and install the one from your DX transmission and connect the speedometer cable to it
