achir21
hi everybody.....
if your sensitive to engines don't look at this....
i bought my EK4 (B16A2) only 2 months ago... . and last while i was at 7500rpm in 5th gear, i suddenly feel a power loss and 2 seconds later....boom ! ... :w00t:....... immediately i realize that my engine blow...
here is the dead beauty...
when i bought the car i found on the trunk a set of 9 scratched bearing .... this failure is surely due to bad bearing work, an over-machined crankshaft, or even for re-using "stressed" rod bolts .... :angry2: f*** mechanics.....
here you can see the trace of the piston when on the head....
you can see that the piston bent the valve seat a bit..... hope the head can be re-used...
ill get the head to the machine shop Saturday for inspection,
im really crossing fingers hope the head can be re-used
if my head is still ok ....... it will be okay, ill get another block and rebuild my engine reliably by myself...
pray with me guys ....
