Korax
Member
Sorry for the double post. Check out this thread. ENG:F22a6 intake manifold swap; coolant refresh; seafoam job; oil/filter change #2 - CB7Tuner Forums
Alot of these have start idle valve problems. It's that little cylinder you see at the top front of the manifold. If you but it on and you idle is erratic I would suggest removing this and putting a blocking plate over it with a gasket (make the plate and gasket yourself). The only time it has problems is when it is really cold out. And even then it is hardly noticeable.
