Will i be okay to run my D16z6 head on a z6 block with Pg6B pistons
tboneair
Im trying to get my 1993 del sol si running again for not too much money and i was able to find a Z6 block with pg6 pistons already inside. My question is will i have piston to valve clearance issues? not looking to upgrade cam just looking to get her running again. Ive clayed the motor and from my findings i have room but as its m first time im not sure i did everything right maybe someone has doe this setup before?
E_SolSi
Member of the 20 nut club
Moderator
VIP
On second check you're right, I think I forgot to chose the z6 head
If it clays out well you should be fine, but compression is up there.
Going to want to make sure your fuel/tune is on point
