zc trans parts into si trans ?...
  • Thread starter Thread starter 4Door89
  • Replies Replies 1
  • Views Views 938
4Door89
so i came across a good deal for zc trans parts, gears,FD and LSD, but no case, can and if so how do i get this to fit into a big bearing si trans case...? (no intermediate shaft)
-what axles to use?
-does it swap over?
-is my only option to get the cases/shaft too?
any help is much needed, thanks
the 88-91 ZC transmission uses the same case as the large bearing 88-91 Si transmission - all of the internal parts will swap right in - the ZC differential (including the factory LSD) requires the use of the intermediate shaft and the larger 90-93 Integra type axles - regular axles for the 88-91 L3 Si/DX/LX/EX/HF/STD will not fit into the ZC differential - the inner CV joint splined end that goes into the transmission is too small in diameter - it is 26mm diameter with 25 splines - the ZC uses 28mm diameter with 27 splines
