b16 injector question
etccatz
i have a b18a motor wired obd1. i have a spare set of b16 injectors lying around and i was wanting to put them in the b18a. now the question is will they give me any gains and will they work considering they are obd0 injectors???? thanks ahead of time
if your wired for obd1 then i dont know if the plugs will work for obd0 injectors but no there will not be any differance because im pretty sure all the b/d series motors run 240 injctors,
The difference is Peak and hold versus Saturated injectors. If you go to OBD0 injectors, you'll need to run a resistor box. This site has the information on how if you so choose; just do a search.
Same size.
For future reference, anytime you modify the injector size to anything other than what the ECU is calibrated for, you HAVE to recalibrate the ECU. Not always does this mean you need a tune, just set up for larger injectors so it's not dumping too much fuel.
I was wondering,
im putting a gsr in my crx,
im wiring it obd1
can i just take off my obd0 injectors and put them on the gsr,
or what do i do to use the obd1 injectors, remove the resistor box
and wire obd1 clips,
any help on this would help
thanks
