b16 injector question
Discussion in 'HYBRID -> ED-EF / DA' started by etccatz, Sep 21, 2008.
  1. etccatz
    etccatz Junior Member
    i have a b18a motor wired obd1. i have a spare set of b16 injectors lying around and i was wanting to put them in the b18a. now the question is will they give me any gains and will they work considering they are obd0 injectors???? thanks ahead of time
  2. INJEN78
    INJEN78 HS LEGEND
    OHIO
    if your wired for obd1 then i dont know if the plugs will work for obd0 injectors but no there will not be any differance because im pretty sure all the b/d series motors run 240 injctors,
  3. red91efhatch
    red91efhatch New Member
    Albuquerque
    he's right all are 240cc. no major difference.
  4. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    The difference is Peak and hold versus Saturated injectors. If you go to OBD0 injectors, you'll need to run a resistor box. This site has the information on how if you so choose; just do a search.
    Same size.
    For future reference, anytime you modify the injector size to anything other than what the ECU is calibrated for, you HAVE to recalibrate the ECU. Not always does this mean you need a tune, just set up for larger injectors so it's not dumping too much fuel.
  5. 90Rex
    90Rex New Member
    I was wondering,
    im putting a gsr in my crx,
    im wiring it obd1
    can i just take off my obd0 injectors and put them on the gsr,
    or what do i do to use the obd1 injectors, remove the resistor box
    and wire obd1 clips,
    any help on this would help
    thanks
