hey guys im looking to rebuild my blown d16z6 vtec engine would like to build it ready for turbo planing on puting one on it later. so heres what i need help with what all would i need to do to build my d16?
a list of stuff i will be needing would be great, thanks kent.
Well you're going about it the wrong way. If you want to build an engine up for turbo then don't worry about adding any horsepower to it at the moment, just worry about making sure it's properly built. How much power do you hope to make with the turbo installed?
PSI is somewhat irrelevant because different turbos will make different numbers at the same PSI. Honestly, if you're looking for 200ish horses then you really don't need to do much. A good stock rebuild plus ARP hardware should work just fine...
yessir.. them studs make a difference in sealing that head gasket. it works better by pulling down on the head instead of pulling up on the block as with factory bolts^_^
