b16a2 no spark
oddballesi
after trying to sorting the wiring out i changed the b16 loom over to me z6 one and then back again after i notice some of the sockets were in different places
The car was running before i done this and now i plugged it back together im getting no SPARK at all it worked before why not now.
thought it was the dizzy so i checked connections all getting the right voltage i have got a brand new one coming.
i havent got the o2 sensor plugged in yet and some random nipple plug on the back of the engine anybody think they would affect it
also everytime i do try and start it theres a strange electrical humming noise
shouldn't taken it apart but shit happens
any solutions cheers guys
Grounds, grounds, grounds, and when you're done checking your grounds, check rour grounds.
check your ignition coil and igniter see if the coil is any good. check primary secondary resistance
Definitely the grounds. Its almost always the one that bolts to the thermostat housing. That one has gotten me before.
Clean with some carb cleaner or something and sand all of your ground with sandpaper along with the grounding surface, i used that to get a good ground with my swap. and once its sanded cover it up with something, maybe plastic caps
