TorontoJdm
QUESTIONS? CALL US NOW!
TOLL FREE NUMBER:
1-877-JDM-0-JDM
1-877-536-0-536
~All the engines we have are in good mint working order.
~Compression test has been done.
~All the motor we sell has strong to perfect compressions.
~Each motor is hand picked in Japan and taken out of running cars.
~We can do the compression test and take pictures of it for potential customers upon request.
I ALSO CARRY LEGEND, 3.2TL, ODYSSEY, ACCORD V6 ALL OTHER ENGINES PLEASE PM ME!
JDM HONDA CIVIC HX 96+ M4VA AUTOMATIC CVT TRANSMISSION $499.99 Shipped
JDM D15B OBD1 VTEC ENGINE $500 + shipping
Complete engine block
head Intake
Exhaust Manifold,
Flywheel AT/MT,
Crankshaft Pulley
Injectors
Valve cover
Spark plug wires
JDM D15B OBD2 NON VTEC $500 + Shipping
and VTEC ENGINE $600 + Shipping
head Intake
Exhaust Manifold,
Flywheel AT/MT,
Crankshaft Pulley
Injectors
Valve cover
Spark plug wires
JDM B16A OBD0 complete $1450 + Shipping
Option LSD Transmission +$300
ENGINE INCLUDES:
ENGINE BLOCK
5 SPEED CABLE TRANSMISSION
INTAKE MANIFOLD
EXHAUST MANIFOLD
DOWN PIPE
FUEL RAIL
THROTTLE BODY
VTEC SOLENOID
DISTRIBUTOR
ALTERNATOR
STARTER
AC COMPRESSOR
POWER STEERING
INJECTORS
SPARK PLUGS
OIL PAN
VALVE COVER
ECU
WIRE HARNESSES
STOCK SENSORS
JDM B16A2 2nd Gen OBD1 Complete $2150 Shipped
ENGINE INCLUDES:
ENGINE BLOCK
5 SPEED HYDRAULIC TRANSMISSION
INTAKE MANIFOLD
EXHAUST MANIFOLD
DOWN PIPE
FUEL RAIL
THROTTLE BODY
VTEC SOLENOID
DISTRIBUTOR
ALTERNATOR
STARTER
AC COMPRESSOR
POWER STEERING PUMP
INJECTORS
SPARK PLUGS
OIL PAN
VALVE COVER
ECU
WIRE HARNESSES
STOCK SENSORS
JDM 96+ B18B Non-Vtec LS complete engine $1699.99 SHIPPED
ENGINE INCLUDES:
ENGINE BLOCK
INTAKE MANIFOLD
EXHAUST MANIFOLD
DOWN PIPE
FUEL RAIL
THROTTLE BODY
DISTRIBUTOR
ALTERNATOR
STARTER
AC COMPRESSOR
POWER STEERING PUMP
INJECTORS
SPARK PLUGS
OIL PAN
VALVE COVER
ECU
WIRE HARNESSES
STOCK SENSORS
JDM B18C GSR OBD1/OBD2 complete engine $2650 + Shipping
Option: LSD Transmission +$300
ENGINE INCLUDES:
ENGINE BLOCK
INTAKE MANIFOLD
EXHAUST MANIFOLD
DOWN PIPE
FUEL RAIL
THROTTLE BODY
VTEC SOLENOID
DISTRIBUTOR
ALTERNATOR
STARTER
AC COMPRESSOR
POWER STEERING PUMP
INJECTORS
SPARK PLUGS
OIL PAN
VALVE COVER
ECU
WIRE HARNESSES
STOCK MOUNTS AND SENSORS
JDM B18C 96 Spec ITR complete engine $3850.00 Shipped!! **ON SPECIAL**
ENGINE BLOCK
5 SPEED LSD TRANSMISSION
INTAKE MANIFOLD
EXHAUST MANIFOLD
DOWN PIPE
FUEL RAIL
THROTTLE BODY
VTEC SOLENOID
DISTRIBUTOR
ALTERNATOR
STARTER
AC COMPRESSOR
POWER STEERING PUMP
INJECTORS
SPARK PLUGS
OIL PAN
VALVE COVER
ECU
WIRE HARNESSES
STOCK SENSORS
JDM B18C 98 Spec ITR complete engine $3950 + Shipping
ENGINE INCLUDES:
ENGINE BLOCK
INTAKE MANIFOLD
EXHAUST MANIFOLD
DOWN PIPE
FUEL RAIL
THROTTLE BODY
VTEC SOLENOID
DISTRIBUTOR
ALTERNATOR
STARTER
AC COMPRESSOR
POWER STEERING PUMP
INJECTORS
SPARK PLUGS
OIL PAN
VALVE COVER
ECU
WIRE HARNESSES
STOCK SENSORS
JDM B20B 96-98 spec engine $750 + Shipped!!
Engine Includes:
engine block
Intake
Exhaust Manifold
Flywheel AT/MT
Crankshaft Pulley
Injectors
Valve cover
Spark Plugs
Spark plug wires
HONDA ACCORD SIR JDM F20B DOHC V-TEC ENGINE SPECIAL $650.00/EACH LONG BLOCK + SHIPPING
ENGINE INCLUDES:
Engine Block and Head
Intake Manifold
Exhaust Manifold
Crankshaft Pulley
Injectors
Valve cover
Dip Stick
Spark plug wires
Spark Plugs
Oil Cap
Oil Pan
92-96 PRELUDE H22A OBD1 ENGINE SWAP $1700+ Shipping
ENGINE BLOCK
INTAKE MANIFOLD
EXHAUST MANIFOLD
FUEL RAIL
THROTTLE BODY
VTEC SOLENOID
DISTRIBUTOR
ALTERNATOR
STARTER
AC COMPRESSOR
POWER STEERING PUMP
INJECCTORS
SPARK PLUGS
OIL PAN
VALVE COVER
USED MIDSHAFT
ECU
WIRE HARNESSES
STOCK SENSORS
97+ PRELUDE H22A OBD2 ENGINE SWAP $2350+ Shipping
ENGINE BLOCK
INTAKE MANIFOLD
EXHAUST MANIFOLD
FUEL RAIL
THROTTLE BODY
VTEC SOLENOID
DISTRIBUTOR
ALTERNATOR
STARTER
AC COMPRESSOR
POWER STEERING PUMP
INJECCTORS
SPARK PLUGS
OIL PAN
VALVE COVER
USED MIDSHAFT
ECU
WIRE HARNESSES
STOCK SENSORS
JDM Accord Euro-R red top H22A complete swap $3399.99 + Shipping
220HP@7200rpm
164Torque@6700rpm
Engine block Top and Bottom
5 Speed LSD Transmission (code: T2W4)
Intake Manifold (Type R Style)
Injectors and Fuel Rail
Spark Plug and Cables
Intermediate shaft
Exhaust Manifold
Oil Pan
Starter
Down Pipe
Valve Cover
Distributor
Alternator
A/C Compressor
Harnesses and ECU
JDM C32A HONDA LEGEND COMPLETE ENGINE WITH AUTOMATIC TRANSMISSION $1150 SHIPPED!
Engine includes:
Intake Manifold
Exhaust Manifold
Down Pipe
Automatic Transmission
Torque Converter & Flywheel
Fuel Rails
Coil Packs
Spark Plugs
Injectors
Starter
Power Steering Pump
Alternator
A/C Compressor
Oil Pan
Valve Cover
Stock Sensors
JDM 98-01 ACCORD V6 3.0L J30A COMPLETE VTEC ENGINE & TRANSMISSION $1250 + SHIPPING
THIS ENGINE PACKAGE INCLUDES:
V6 3.0L ENGINE BLOCK
EXHAUST MANIFOLD
INTAKE MANIFOLD
FUEL RAIL
THROTTLE BODY
ALTERNATOR
STARTER
AC COMPRESSOR
COILPACK
INJECTORS
SPARK PLUGS
SPARK PLUG COVER
OIL PAN
VALVE COVER
ALL STOCK SENSORS
JDM 01-03 ACURA 3.2 TL Type-S J32A V6 VTEC ENGINE+AUTOMATIC TRANSMISSION $2499.99 Shipped
ENGINE INCLUDES:
ENGINE BLOCK
AUTOMATIC TIPTRONIC TRANSMISSION
INTAKE MANIFOLD
EXHAUST MANIFOLD
FUEL RAIL
THROTTLE BODY
COIL PACKS
ALTERNATOR
STARTER
AC COMPRESSOR
POWER STEERING PUMP
INJECTORS
SPARK PLUGS
OIL PAN
VALVE COVER
STOCK SENSORS
DC5-R K20A 6 Speed LSD Complete Swap we have in stock. $4999.99
Please contact us!
Please PM me if you have any questions, or call 1-877-536-0-536 Karim
