2010 Honda Complete Engine Pricing TorontoJDM.com
Discussion in 'Parts: For Sale/Trade/Wanted' started by TorontoJdm, Feb 4, 2010.
  1. TorontoJdm
    TorontoJdm New Member
    TorontoJDM.com
    QUESTIONS? CALL US NOW!
    TOLL FREE NUMBER:
    1-877-JDM-0-JDM
    1-877-536-0-536
    ~All the engines we have are in good mint working order.
    ~Compression test has been done.
    ~All the motor we sell has strong to perfect compressions.
    ~Each motor is hand picked in Japan and taken out of running cars.
    ~We can do the compression test and take pictures of it for potential customers upon request.
    I ALSO CARRY LEGEND, 3.2TL, ODYSSEY, ACCORD V6 ALL OTHER ENGINES PLEASE PM ME!
    JDM HONDA CIVIC HX 96+ M4VA AUTOMATIC CVT TRANSMISSION $499.99 Shipped
    JDM D15B OBD1 VTEC ENGINE $500 + shipping
    Complete engine block
    head Intake
    Exhaust Manifold,
    Flywheel AT/MT,
    Crankshaft Pulley
    Injectors
    Valve cover
    Spark plug wires
    JDM D15B OBD2 NON VTEC $500 + Shipping
    and VTEC ENGINE
    $600 + Shipping
    head Intake
    Exhaust Manifold,
    Flywheel AT/MT,
    Crankshaft Pulley
    Injectors
    Valve cover
    Spark plug wires
    JDM B16A OBD0 complete $1450 + Shipping
    Option LSD Transmission +$300
    ENGINE INCLUDES:
    ENGINE BLOCK
    5 SPEED CABLE TRANSMISSION
    INTAKE MANIFOLD
    EXHAUST MANIFOLD
    DOWN PIPE
    FUEL RAIL
    THROTTLE BODY
    VTEC SOLENOID
    DISTRIBUTOR
    ALTERNATOR
    STARTER
    AC COMPRESSOR
    POWER STEERING
    INJECTORS
    SPARK PLUGS
    OIL PAN
    VALVE COVER
    ECU
    WIRE HARNESSES
    STOCK SENSORS
    JDM B16A2 2nd Gen OBD1 Complete $2150 Shipped
    ENGINE INCLUDES:
    ENGINE BLOCK
    5 SPEED HYDRAULIC TRANSMISSION
    INTAKE MANIFOLD
    EXHAUST MANIFOLD
    DOWN PIPE
    FUEL RAIL
    THROTTLE BODY
    VTEC SOLENOID
    DISTRIBUTOR
    ALTERNATOR
    STARTER
    AC COMPRESSOR
    POWER STEERING PUMP
    INJECTORS
    SPARK PLUGS
    OIL PAN
    VALVE COVER
    ECU
    WIRE HARNESSES
    STOCK SENSORS
    JDM 96+ B18B Non-Vtec LS complete engine $1699.99 SHIPPED
    ENGINE INCLUDES:
    ENGINE BLOCK
    INTAKE MANIFOLD
    EXHAUST MANIFOLD
    DOWN PIPE
    FUEL RAIL
    THROTTLE BODY
    DISTRIBUTOR
    ALTERNATOR
    STARTER
    AC COMPRESSOR
    POWER STEERING PUMP
    INJECTORS
    SPARK PLUGS
    OIL PAN
    VALVE COVER
    ECU
    WIRE HARNESSES
    STOCK SENSORS
    JDM B18C GSR OBD1/OBD2 complete engine $2650 + Shipping
    Option: LSD Transmission +$300
    ENGINE INCLUDES:
    ENGINE BLOCK
    INTAKE MANIFOLD
    EXHAUST MANIFOLD
    DOWN PIPE
    FUEL RAIL
    THROTTLE BODY
    VTEC SOLENOID
    DISTRIBUTOR
    ALTERNATOR
    STARTER
    AC COMPRESSOR
    POWER STEERING PUMP
    INJECTORS
    SPARK PLUGS
    OIL PAN
    VALVE COVER
    ECU
    WIRE HARNESSES
    STOCK MOUNTS AND SENSORS
    JDM B18C 96 Spec ITR complete engine $3850.00 Shipped!! **ON SPECIAL**
    ENGINE BLOCK
    5 SPEED LSD TRANSMISSION
    INTAKE MANIFOLD
    EXHAUST MANIFOLD
    DOWN PIPE
    FUEL RAIL
    THROTTLE BODY
    VTEC SOLENOID
    DISTRIBUTOR
    ALTERNATOR
    STARTER
    AC COMPRESSOR
    POWER STEERING PUMP
    INJECTORS
    SPARK PLUGS
    OIL PAN
    VALVE COVER
    ECU
    WIRE HARNESSES
    STOCK SENSORS
    JDM B18C 98 Spec ITR complete engine $3950 + Shipping
    ENGINE INCLUDES:
    ENGINE BLOCK
    INTAKE MANIFOLD
    EXHAUST MANIFOLD
    DOWN PIPE
    FUEL RAIL
    THROTTLE BODY
    VTEC SOLENOID
    DISTRIBUTOR
    ALTERNATOR
    STARTER
    AC COMPRESSOR
    POWER STEERING PUMP
    INJECTORS
    SPARK PLUGS
    OIL PAN
    VALVE COVER
    ECU
    WIRE HARNESSES
    STOCK SENSORS
    JDM B20B 96-98 spec engine $750 + Shipped!!
    Engine Includes:
    engine block
    Intake
    Exhaust Manifold
    Flywheel AT/MT
    Crankshaft Pulley
    Injectors
    Valve cover
    Spark Plugs
    Spark plug wires
    HONDA ACCORD SIR JDM F20B DOHC V-TEC ENGINE SPECIAL $650.00/EACH LONG BLOCK + SHIPPING
    ENGINE INCLUDES:
    Engine Block and Head
    Intake Manifold
    Exhaust Manifold
    Crankshaft Pulley
    Injectors
    Valve cover
    Dip Stick
    Spark plug wires
    Spark Plugs
    Oil Cap
    Oil Pan
    92-96 PRELUDE H22A OBD1 ENGINE SWAP $1700+ Shipping
    ENGINE BLOCK
    INTAKE MANIFOLD
    EXHAUST MANIFOLD
    FUEL RAIL
    THROTTLE BODY
    VTEC SOLENOID
    DISTRIBUTOR
    ALTERNATOR
    STARTER
    AC COMPRESSOR
    POWER STEERING PUMP
    INJECCTORS
    SPARK PLUGS
    OIL PAN
    VALVE COVER
    USED MIDSHAFT
    ECU
    WIRE HARNESSES
    STOCK SENSORS
    97+ PRELUDE H22A OBD2 ENGINE SWAP $2350+ Shipping
    ENGINE BLOCK
    INTAKE MANIFOLD
    EXHAUST MANIFOLD
    FUEL RAIL
    THROTTLE BODY
    VTEC SOLENOID
    DISTRIBUTOR
    ALTERNATOR
    STARTER
    AC COMPRESSOR
    POWER STEERING PUMP
    INJECCTORS
    SPARK PLUGS
    OIL PAN
    VALVE COVER
    USED MIDSHAFT
    ECU
    WIRE HARNESSES
    STOCK SENSORS
    JDM Accord Euro-R red top H22A complete swap $3399.99 + Shipping
    220HP@7200rpm
    164Torque@6700rpm
    Engine block Top and Bottom
    5 Speed LSD Transmission (code: T2W4)
    Intake Manifold (Type R Style)
    Injectors and Fuel Rail
    Spark Plug and Cables
    Intermediate shaft
    Exhaust Manifold
    Oil Pan
    Starter
    Down Pipe
    Valve Cover
    Distributor
    Alternator
    A/C Compressor
    Harnesses and ECU
    JDM C32A HONDA LEGEND COMPLETE ENGINE WITH AUTOMATIC TRANSMISSION $1150 SHIPPED!
    Engine includes:
    Intake Manifold
    Exhaust Manifold
    Down Pipe
    Automatic Transmission
    Torque Converter & Flywheel
    Fuel Rails
    Coil Packs
    Spark Plugs
    Injectors
    Starter
    Power Steering Pump
    Alternator
    A/C Compressor
    Oil Pan
    Valve Cover
    Stock Sensors
    JDM 98-01 ACCORD V6 3.0L J30A COMPLETE VTEC ENGINE & TRANSMISSION $1250 + SHIPPING
    THIS ENGINE PACKAGE INCLUDES:
    V6 3.0L ENGINE BLOCK
    EXHAUST MANIFOLD
    INTAKE MANIFOLD
    FUEL RAIL
    THROTTLE BODY
    ALTERNATOR
    STARTER
    AC COMPRESSOR
    COILPACK
    INJECTORS
    SPARK PLUGS
    SPARK PLUG COVER
    OIL PAN
    VALVE COVER
    ALL STOCK SENSORS
    JDM 01-03 ACURA 3.2 TL Type-S J32A V6 VTEC ENGINE+AUTOMATIC TRANSMISSION $2499.99 Shipped
    ENGINE INCLUDES:
    ENGINE BLOCK
    AUTOMATIC TIPTRONIC TRANSMISSION
    INTAKE MANIFOLD
    EXHAUST MANIFOLD
    FUEL RAIL
    THROTTLE BODY
    COIL PACKS
    ALTERNATOR
    STARTER
    AC COMPRESSOR
    POWER STEERING PUMP
    INJECTORS
    SPARK PLUGS
    OIL PAN
    VALVE COVER
    STOCK SENSORS
    DC5-R K20A 6 Speed LSD Complete Swap we have in stock. $4999.99
    Please contact us!
    Please PM me if you have any questions, or call 1-877-536-0-536 Karim
  2. Briansol
    Nice Prices for 2010 :) A Great welcome back to HondaSwap!
  3. TorontoJdm
    TorontoJDM.com
    thank you very much Brain, glad to be here :)
  4. TorontoJdm
    TorontoJDM.com
    New shipment arrived ...Let us know what you need..Thanks!
  5. Matts96HB
    Matts96HB . Moderator VIP
    wow, bump for some good prices here
    i can also vouch as i bought my swap from toronto jdm
    and it was EXTREMELY clean when i pulled the engine apart to build it :D
  6. Andrew
    Andrew Well-Known Member
    Tallahassee, FL
    Great prices!
    Do you import B20's?
  7. TorontoJdm
    TorontoJDM.com
  8. Andrew
    Tallahassee, FL
    Got your message. I will talk to you there. Thanks!
  9. TorontoJdm
    TorontoJDM.com
  10. TorontoJdm
    TorontoJDM.com
    toll free # now available!
  11. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    My brother just ordered ITR suspension from you guys, GREAT price!
    Free bump
    btw, are you guys able to get the JDM rear bumper support for the 88-91Civic hatchbacks?
  12. TorontoJdm
    TorontoJDM.com
    not for that car :( sorry!
  13. TorontoJdm
    TorontoJDM.com
  14. nofxSOHCcrx
    nofxSOHCcrx New Member
    Las Vegas, NV
    `anyway you could pm me with the price for a B20Z with and without tranny?
  15. TorontoJdm
    TorontoJDM.com
  16. TorontoJdm
    TorontoJDM.com
  17. SiiK Ef
    SiiK Ef New Member
    Is there anyway ou guys could get ahold of a ls B18A if so you can pmme and let me know some prices. Thanks, Ryan
  18. SiiK Ef
    SiiK Ef New Member
    also is toronto jdm aka tiger japanese???
  19. TorontoJdm
    TorontoJDM.com
    your account cannot be pm'ed but i sent you an e-mail thru your account.
    $775.00 USD shipped anywhere in USA
    Please check this link
    http://www.torontojdm.com/lite/cart.php?target=product&product_id=3517&category_id=101
    no we are NOT tiger japanese :)
  20. SiiK Ef
    SiiK Ef New Member
    Ok cool thanks alot. I will check out the link and hopefully do some business.
