Obd1 p30
Sohc 2000
Hey does any one know how I can get the pinouts for a obd1 p30 ecu b16a Manual
.:FFS TechNet : OBD1 ECU Pin out Schematics :.
Hey I have a d16zc vtev manual motor I change the harness to obd1 an I running a b16a manual p30 ECU obd1 my check lights comes on and stays on I get a very low idle an 2 codes show up when I check it ( oxygen heat sensor)and(oxygen sensor) what's causing this?an what can I do?
Put a P28 in it like the D16Z6 wants
Then check your O2 sensor and the wiring to it
