Obd1 p30
Discussion in 'Civic and del Sol - EG and EK' started by Sohc 2000, Jan 21, 2013.
  1. Sohc 2000
    Sohc 2000 New Member
    Hey does any one know how I can get the pinouts for a obd1 p30 ecu b16a Manual
  2. E_SolSi
  3. Sohc 2000
  4. Sohc 2000
    Hey I have a d16zc vtev manual motor I change the harness to obd1 an I running a b16a manual p30 ECU obd1 my check lights comes on and stays on I get a very low idle an 2 codes show up when I check it ( oxygen heat sensor)and(oxygen sensor) what's causing this?an what can I do?
  5. E_SolSi
    Put a P28 in it like the D16Z6 wants
    Then check your O2 sensor and the wiring to it
  6. Greenmachine93
    Greenmachine93 New Member
    What about for a non vtec zc?
