civicjason
What did the fluid look like that came out of the transmission before you ran it?
Well after further inspection the trans fluid appears to be coming from where the axles shaft meets the transmission so the best guess is that the gasket was pinched or failed there.
Also a spark plug check showed two plugs were white which is a lean condition correct? And the other two had oil around them so I'm hoping only a gasket issue there.
