ok i have a set of b16 pistons and im wanna put them in my ls/vtec.. i also have a b16 head..... will i have enough valve clearance to use them? and what wrist pin would i use???
No. Do not use the B16 rods. If you do, you'll have a really super low compression LS. The stock rods fit. If you're worried about the valve clearance (will be ok with stock cam timing and stock cams), use clay to check your clearances. The stock wrist pins work fine.
