yes, yes. repeating what has already been said. hmmm... must be the smart thing to do if 3 people suggest it.just swap over the whole b20.. no need to change the head ..
yes. you might want to get it tuned though.I can still us the ls ecu and everything will start and run like it should right.
cometic. they are good and affordable.what type of head gasket would you recoment get nick
B20 water pump and B18A timing belt. You use the timing belt that goes with the head on head swaps.
Dude. Fuck you.
No, that was for acting like you've never flamed a newbie before...which you used to do quite frequently. If I'm wrong I learn. And yeah dude, I don't know anything about engines or head swaps. I'm a total goober. Ahyuck.
Another question. will the b18 oil pan work with the b20 block?
