Antifreeze coming out of the tailpipe
Antifreeze
Okay...got the head back on, but have a steady oil leak from one area...plus...my intake man is sucking air...so...will have to pull that back off and try, try again...crazy!
this is why we said to swap the motor. it's never as easy as just swapping the head. i guarantee when all is said and done you will have wish you just did the motor.
where is the leak? and for the IM, check all your vacuums. hopefully you replaced the IM gasket.
Sputting when accelorating
Need help. When I take off in first gear an the RPMs get up, my car sputters...like it is turning off and starting back up. It does it in the other gears too...if I don't get the RPMs too high it doesn't do it...but If I need to "get on it" it sputters out. All vacuum hoses connedted, etc...I am at a loss...please help.
Rick
Did it today...check engine light still on...code still says O2 sensor. Before the problem the check engine light would come on and if you turn the car on and off while driving, it would go off and stay off...
well its almost got to be something in the fuel or fireing, or that o2
