jdm dohc f22b , youll have to do nothing really its a pretty straight forward swap.
He could also be talking about the 94-97 single-cam motor. Either way, like you said, it's pretty much a bolt-in swap. If it's the DOHC version then use the dual-cam ECU.
h23 ecu will work for the dohc. If your gonna go f22b sohc, dont youll be gooing backwards if you do.
Go here... CB7Tuner Forums - powered by vBulletin Later
I got a Vtech F22 motor in my accord, LX body. just put in a chipped ECU in my car since Vtech wasn"t popping and now it pops but I want to rewire the Vtech since it was piggy backed into the stock ECU how can I make the Vtech pop faster?
