F22B Swap help
Discussion in 'Accord' started by Arr777, Feb 5, 2008.
  1. Arr777
    Arr777 New Member
    Im thinkin about putting a [FONT=arial, helvetica]F22B in my 93 accord lx, i was wonder what i would have to do to make it work, step by step instructions would be nice to some info on how to get them, thanks
    [/FONT]
  2. D15Beater
    D15Beater HNFTuning
    Concord N.C.
    jdm dohc f22b , youll have to do nothing really its a pretty straight forward swap.
  3. BrutalB83
    Rochester Hills, MI
    He could also be talking about the 94-97 single-cam motor. Either way, like you said, it's pretty much a bolt-in swap. If it's the DOHC version then use the dual-cam ECU.
  4. D15Beater
    D15Beater HNFTuning
    Concord N.C.
    h23 ecu will work for the dohc. If your gonna go f22b sohc, dont youll be gooing backwards if you do.
  5. BrutalB83
    Rochester Hills, MI
    Why would an F22B single cam be "going backwards"? Yeah, it's not much of an upgrade, but it's still an upgrade. The 94-97 F22s have a few more horsepower than the 90-93 versions. It would probably have lower miles as well.
  6. Arr777
    Arr777 New Member
    Ya im doing the DOHC swap i was juss wonder if like sensors, and ecu, and the other components would be a direct swap, and if not which ones would i need, and what cars i would need to get the parts from
    thanks alot for the help
  7. D15Beater
    D15Beater HNFTuning
    Concord N.C.
  8. BrutalB83
    Rochester Hills, MI
    So you direct him to a different forum for a question that can easily be answered here?
    Anyways, to the OP: The dual-cam F22B is a direct drop-in swap. It's pretty much the exact same thing as an H23. As long as the swap motor is OBD1, then everything should bolt up and plug in easily. The ECU for your single-cam F22 won't run the new motor very well, so you'll need to swap it out. Use the ECU that comes with the motor, or you can also use one from an H23 if your motor didn't come with one. Like I said, as long as the new motor is OBD1, then everything, including the ECU, should be plug n' play.
    Good luck.
  9. 94hondaaccord
    94hondaaccord honda LX Vtech
    brooklyn
    I got a Vtech F22 motor in my accord, LX body. just put in a chipped ECU in my car since Vtech wasn"t popping and now it pops but I want to rewire the Vtech since it was piggy backed into the stock ECU how can I make the Vtech pop faster?
  10. powerdriverh22
    powerdriverh22 Senior Member
    spfld, mo
    well honda's dont have vtech. they have vtec. and last i knew it didnt "pop". what do you mean vtec is piggy backed to the stock ecu? are you saying that you have a piggy back (ie vafc or safc)? you are not going to be able to make the "vtech pop faster" with a piggy back style computer...unless its hondata. you could get a vtec controller, but in my opinion they are useless. your vtec is set at a point that is optimum for the engine. and btw i thought that the doch f22b's were non vtec. or are you talking about the f22b1 sohc ex vtec motor?
  11. BrutalB83
    Rochester Hills, MI
    What do you mean by "chipped ECU"? If it's one of those cheapo 'Mugen' or 'Spoon' chips you see on eBay, then it's garbage...
