Reverend Awptickes
Ride: 1999 Civic EJ9, 2009 Fit GE8, 2006 Suzuki SV650s
A common question from many new folks is "When do I shift?"
There are a few answers that newbies get, and some are wrong, some are right. This is just another method to use. First, you'll want to get the gear ratios. Plug the gear ratios into this site: http://www.housemanautosport.com/ratio%20calculator.htm ![]() Then you'll need the diameter of your drive tires. Every tire is different, and wears differently, so you'll need to use your judgement. I plug it into the miata.net tire calculator: Tire size calculator ![]() Input the data you just collected, and submit it. Now you'll have some numbers, use these to work by. Go to a strip and test them out. There's some experimentation, but it's pretty on-the-money. Now, stop asking "When do I shift?". |
I'll be back...
Ride: 06 Mazda 5, 91 Civic DX
IMO, this way is wrong as well. You don't come up with your shift points by looking at your speedometer...
You get your fucking car on the dyno, see where the power band is, then figure out the shift point that allows you to stay in your power band. __________________
Real Eyes Realize Real Lies |
Regular Member w/ Cheese
Ride: 2000 EJ8 w/ SiR-II
The only problem I see with your method Awptickles, would be with the gear calculator. The average noob says, "I have a B16, so lets see, modify the rev limit value from 8000 to 9000. Sweet that should make me faster".
Which is why I agree with knowing your powerband. And it's not only about the shift on the increase of rpm, but where the motor is after the shift, at the begining of the next gear as well. Good attempt. __________________
YBLEGAL.NET → Profile • Projects • Parts For Sale → Steel Braided Brake Lines • Front Camber Kit (Price Drop) • Manual Brake Pedal |
#5 |
Administrator
Ride: 318ti, dakota, genesis 2.0t
the IDEAL shift point is a shift that leaves your horsepower peak, and lands you on your torque peak.
if your car redlines at 8000, but peak hp is at 7000, on paper it doesn't make sense to wind it out. BUT if shifting at 8k drops you to 4k, and at 7k drops you to 3.5k, odds are that you're more in your torque band at 4k. So, you're making more power from 7-8k then you are torque, proportionally from 3.5-4k, thus it's usually logical (on honda motors) to rev it all the way out. so, yes, gearing (and even tire size) play into where you land... but it needs to be x-referenced against your peak hp point and peak torque point, and then averaged, and then rationalized, and .... i don't know... too much math. just wing it out ![]() |
#6 |
A good driver can feel the math
![]() __________________
#8 |
Running on two cylinders
Ride: 2000 Mitsubishi Lancer RPW E5 Coupe
i shift when i feel like it, gosh!
Home of the RPW built 2000 Lancer CC Coupe. See what is done to the little Evo5. "If you don't like what I've done with my car, I will gladly refund all the money you put into it." |
#9 | |
!!YTINASNI
No shit. Drive the car. You'll just know when to shift.
#10 | |
Member of the 20 nut club
hit the rev limiter count to 10 then shift
МОΛΏΝ ΛΑΒΈ |
#11 |
is lol'ing @ you
^ Fuckin bingo! Thats it!
#14 |
Ride: 1999 Honda Civic EX
ok i took this advice..it seemed to work great! my car is 20 times faster shifting like that i dont know why i didn't do it sooner! Does that work for all gears? I tried it on launch as well!! Other than some awful wheel hop it took off like a rocket!
#16 | |
^^ Likes Bewbies
Ride: Rex, Yamaha Virago, CB900F Supersport
Neutral drops give you better takoffs...
#17 | ||
for launch just hold the clutch and gas pedal to the floor when it hits the rev limiter count to 10 and dump the clutch, this will get you your best possible launch (this is the trick the magazines use to get their test results) if you find you are getting a lot of wheel spin when launching like this, you need to warm up the tires more... for a FWD car the best way to do this is to put it in reverse, cut the wheel all the way to the right or left, stomp on the throttle using the same rev limiter 10 count that you want to use for the launch, then dump the clutch and count 10 full revolutions of the car, when finished turn the wheel the other way and repeat the process... after this your tires will be properly warmed up and you should get a sweet launch if you are still spinning a lot on the launch you may need a wider and softer tire __________________
МОΛΏΝ ΛΑΒΈ |
#18 | ||
^^ Likes Bewbies
#19 |
kid that everyone loves!
Ride: 91 accrod DX with a few extras : )
hah lol
heres my mod. list ![]() -painted valve cover -new headers -new high flow obx resonator -new carbon fiber exaust tip -new p.s pump -new radiator -new belt -new injen ram intake -new strut bar -new deck (installed myself) -new speakers -not bad for learning as i went and not having shit for help besides u great guys i think thats around all i did, tok a few months but im happy with it! and after all that theres a small puddle of oil under my intake on my engine..... the fun never ends! |
#20 | |
I still know everything
Ride: 89 CRX HF, 96 Accord EX, 88 Dodge Daytona Shelbyz T-tops
If someone wanted to know any of this information, why not just look at your speed as you shift? __________________
Formerly the.original.kermit Back from the dead... twice I NEED PARTS!!! http://hondaswap.com/parts-sale-trade-wanted/wtb-1989-crx-parts-161172/#post1079066 Check out my progress... http://hondaswap.com/auto-multi-media/my-1989-crx-project-144941/ |
#21 |
Because then more people would be putting it in the ditch...
#22 |
Good, they deserve to be there. Get some of these idiots of the roads.
#23 | |
WOW took this advice and it worked to perfection! I thought it felt like a rocket the first time i tried it! Only this time I did it for a street race in the middle of rush hour traffic for pink slips! Totally won an EVO VIII that guy had no idea what he was facing! |
#24 | |
Ride: 88 Honda Civic HB
#25 | ||
awesome happy to help ![]() __________________
МОΛΏΝ ΛΑΒΈ |
| FS: GSR Hydro Tranny Parts > Shift Forks , Reverse Change Holder , Shift Mechanism .. | D See 2 | Parts: For Sale/Trade/Wanted | 1 | 11-29-2006 11:08 PM |
| shift linkage Shift cable? | Ignorant import guy | HYBRID -> EG-EK / DC | 3 | 02-04-2006 11:14 AM |
| TOP SHIFT | SiR_Redneck | Computers, Games, Electronics etc | 2 | 03-19-2005 12:52 PM |
| where should i shift | 92Gsrhatch | Racing and Driving Techniques | 5 | 03-09-2004 10:32 PM |
| when do you shift? | littlehatch | General Tech and Maintenance | 2 | 12-23-2003 10:07 PM |
