1991 Honda Civic Zc problems
Discussion in 'Civic and CRX - EF' started by intheearlyhours, Jun 29, 2009.
  1. intheearlyhours
    intheearlyhours New Member
    Yo, i got a 91 hatch with a JDM ZC motor in it and here is the problem im having. My car is backfiring and running really bad and i already got new plugs and wires did the timing and everything the is involed with timing. I advanced the dizzy all the way and it fixed it for a couple days. I cant think of what it is. Valves maybe i dont know please help.
  2. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    Any CEL's? When does it make these burps and back fires? At idle?
    Give as much info as possible and make sure to add something tomorrow (reply) when more
    people are on the site and it can be put to the top of the new posts
  3. intheearlyhours
    it backfires pretty much all the time. more when i hit the gas. im not super good with cars so im not sure what alot of shit is called yet. Uhm i also made sure that the firing order was correct. 1342. i might be able to take a video of it making the noise when its sitting in a parking spot if i can get some help.
  4. intheearlyhours
    oh and no check engine light
  5. pappaj
    pappaj New Member
    woodstock
    you need to double check your crank and camshaft timing.
    how is the fuel mileage?
    maybe your injectors are leaky
  6. intheearlyhours
    ok ill double check the timing the fuel mileage seemed bad after i advanced the dizzy but not super bad, how to i check for leaky injectors an easy way lol.
  7. jlicrx
    jlicrx Senior Member
    Colorado Springs
    are you sure that the spark plug wires are in the correct locations on the distributor cap? - the DOHC ZC is not the same as SOHC
    SOHC:
    3 4
    1 2
    DOHC:
    1 3
    2 4
    like this:
  8. intheearlyhours
    Yeah I'm sure the wiring is right. I actually used that picture to check a week ago. Lol
  9. intheearlyhours
    ok i took a short video and for some reason it cut out the part when im under the hood but ill post it anyways. Uhh turn your volume up cause the mic is quite.
    Qik | intheearlyhours | tsdedst
  10. intheearlyhours
    Why does everyone give up on my threads so fast. i get like one reply and then nothing lol. Anyone know a more active forum?
  11. Fernpatch
    Fernpatch Member
    Bellingham,WA
    what distributor are you running? Have you moved the cam position sensor at all? I had a problem like that about a year ago and it was an electrical problem with a splice under the intake manifold. If I can remember more details i will post again later.
