1993 Honda del Sol Si D16z6 B16a3 swap
Discussion in 'Civic and del Sol - EG and EK' started by senna12, Oct 7, 2010.
  1. senna12
    senna12 New Member
    I am planning on swapping a b16a3 into my 93 del Sol si. I have a few questions as to what components i can keep and which components i need to replace. I need to know if i need to replace:
    1) Half-shafts
    2) Radiator
    3) Power Steering System
    4) Clutch Master Cylinder
    5) Brake Hydraulics
    6) Heating and AC systems
    7) Shift Linkage
    8) Ignition system
    9) Fuel Delivery systems
    10) Front Wheel Hubs and Ball Joints
    I am still searching for an engine, I am wondering if anyone has a reputable dealer that they have had a good experience with!
    I am new to engine swapping, so tips would be useful!
    Thanks!
  2. E_SolSi
    **EDIT**
    i fucked this all up.... see post below for info :ph34r:
  3. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    E, you're all backwards y0, he needs to know if he needs to replace those things :)
    Halfshaft - replace with DelSol Vtec's
    Radiator - can keep yous, or upgrade
    Power Steering System - replace with Delsol vtec's
    Clutch Master Cylinder - keep yours
    Brake Hydraulics - keep yours, unless you are upgrading the brakes too, then use the Delsol vtec's master cylinder and booster along with prop valve
    Heating and AC systems - Use DelSol vtec's bracket
    Shift Linkage - replace with DelSol vtec's
    Ignition system - B16A3's
    Fuel Delivery systems - keep yours
    Front Wheel Hubs and Ball Joints - keep yours
    :yes:
  4. E_SolSi
    fuck... woops... misread that...
    time to do some editing :)
  5. senna12
    senna12 New Member
    Excellent, thanks for your help!
    One further question: which motor mounts do i need, and where can i find them?
  6. xj0hnx
    C.C.TX.
    Use the mounts from the DelSol vtec
  7. Blakwolf9666
    Blakwolf9666 Member
    Miami
    if you need to get rid of that z6 head let me know im looking for one for a mini me swap pm me if/when you swap
