CA 1994 Gsr cylinder head with new valves
Discussion in 'Parts: For Sale/Trade/Wanted' started by monotech, Jul 31, 2008.
  1. monotech
    monotech Member
    Taking offers, please no low ballers!...
    1994 ACURA INTEGRA GSR DOHC V-TEC HEAD
    HEAD STAMPING CODE: P72-2
    FITS: B-SERIES ENGINES
    B16 B17 B18a/b B18C b20b/z
    WILL COME WITH A OBD-1 P28 STOCK ECU (VIRGIN) 5 SPEED
    "PERFECT FOR LS/CRV V-TEC CONVERSIONS"
    THE WORKS:
    *NeW GSR VALVES, MILD PORT ON THE INTAKE SIDE, 3 ANGLE VALVE JOB, STOCK VALVE TRAIN, CAMSHAFTS & CAM SPROCKETS, CAM CAPS & RAILS, CAM CAP BOLTS MISSING ONLY 1 STUD $4 BOLT NEW THROUGH ACURA, V-TEC SOLENOID, SENSORS, INTAKE STUDS & NUTS, EXHAUST STUDS, BRIGHT ORANGE VALVE COVER & OIL CAP, HAS BEEN LIGHTLY OILED WITH TORCO ASSEMBLY LUBE TO PREVENT ANY RUST DURING SHIPPING.
    NO HEAD BOLTS. THIS CYLINDER HEAD CAME OFF A FULLY BUILT BOTTUM END GSR BLOCK WITH HIGH COMPRESSION PISTONS BUT CUSTOMER CRACKED A SLEEVE AND HAS DECIDED TO TRY A NEW SET UP AND HAS BEEN REBUILT SINCE. THIS CYLINDER HEAD IS CLEAN & IN STOCK FORM BESIDES THE INTAKE MILD PORT JOB BUT OTHER THAN THAT IT'S STOCK W/ STOCK INTERNALS AND 3 ANGLE VALVE JOB. REMEMBER IT'S NOT MILLED SO YOU CAN USE NITROUS, TURBO, SUPER CHARGE OR HIGH COMPRESSION BUILD UPS. JUST THE NEW VALVES ALONE ARE NEARLY $200 PLUS RESURFACE, HOT TANKING, PORT JOB ON INTAKE SIDE FOR MORE AIR FLOW, COMLPETE VALVE JOB W/ 3 ANGLE, AND PRESSURE TEST, ETC. WILL BE SOLD AS IS, HAS BEEN PRESSURE TESTED AND MACHINED BY A PROFESSIONAL MACHINIST. IF YOU HAVE ANY FURTHER QUESTIONS FEEL FREE TO ASK.
    HARNESS CONVERSIONS/ENGINE SWAPS & MORE........ :cool:
