Got into ripping the wheel apart today to install the factory modified stalk. took all of 20 minutes.
airbag comes off with a T30 torx bit. one there you can disconnect the clockspring plug off the airbag, and the multimedia controls from the clockspring. wheel comes off with a 19mm socket (i used the SAE equivalent since my 19 went missing) .
console comes apart with 2 phillips screws in the front, and one underneath, then from the wheel gap using a thin standard screwdriver (or a plastic trim wrench) just pop up the 2 clips you see in the front and you can separate the rest without much force. the clockspring is held on by 2 or 3 compression clips just give it a good tug and it should come off, i dropped it into the lower cover. you can hold it with a piece of tape if you like, to keep it from spinning. i didn't see it necessary.
the right stalk pops off with one big compression clip.
the left one has 2 phillips screws, one at 12 oclock the other at 6 oclock and an electrical plug on the back. just pulls forward off the column.
heyyy XD
Installation is the reverse of removal. i stopped taking photos since it started to rain... I pulled and tilted the wheel as far as it would go and ziptied the foglamp wires from the stalk to the column and ran them toward the fusebox for now. next step is to put the big plug through the FW to connect with the engine bay harness, and the other wise goes to the fusebox for relay power.
