so i built an IC sprayer.
6 small zip ties
6 feet of 7/32 vacuum / sprayer hose
1/4 inch drill bit
10ft of 1/4in OD copper tubing
dewalt 1/16 split point drill bit
using my cold side resonator pipe to roll the ends of the pipe into U shapes
after getting about the desired shape, i flattened it by hand using a hammer and 2x4 to make it easier to drill the holes. i also crimped the bottom shut.
then i drilled 5 rows of 5 holes making the top holes a little bigger than the bottom ones.
TEST!
now that is that! after taking the bumper off... time to get the chute off the IC, by taking off the crash bar and horn.
after removing the crash bar, 2 10mm bolts and it just lifts up/out.
i did take the opportunity to clean my IC and straighten any bad fins.
i drilled some holes into the crash bar to support and zip tie the piping, and bent it to fit the intercooler perfectly. i have about 1.5 inch to .5 inch clearance following the crash bar curve to the IC.
once the bar is tight and you're happy with your placement... here at the spray bottle, the nipple pointing forward is for the rear sprayer.
and TEST
and here it is!
