4th Gen D15b Power?
Discussion in 'Engine Building' started by Jake 21, Feb 23, 2003.
  1. Jake 21
    Jake 21 Junior Member
    Four corners area, Utah
    I just bought a 91dx hb civic for $150 it has an auto trans and no compression due to rings (I've already got the engine out and apart) Is there a v-tec head that I can put on the block? what do I need? any other tricks?
    :angry:
  2. BigJ
    put zc pistons in it. talk to to Domeskilla he is building a mini-me that will put out like 170 hp and 130-140 ft/lb of torque.
  3. Jeef
    Jeef NO MA'AM Moderator VIP
    Search for the mini me on here. You can use the z6 or y8 head. If I were you I would just swap in a crx si engine so you do not have to fuck with wiring vtec and you will have the proper fuel curves without wiring for obd1.
