hello anyone, I need madd help and im not expecting any but god damn do i need it , i just did a tranny motor swap from my 90 integra LS with a B16a OBD MPFI, I swapped it over last weekend into a civic 94 dx automatic, i took the D15b7 with auto tranny out and put my b16a with cable 5 speed in and everything bolts in great after customizing and welding rear and front engine mounts the sides were a direct fit, i ran into a wiring problem from trying to make my own jumper harness using my Pr3 ecu since its mugen chipped i wanted to use it , so my original plan was to use my obd harness from the integra but its so well hidden and too much bullshyt to take it all off the body so i just took the injector harness from my OBD and i left the civic DX obd1 harness in the civic, problem is i already cut the ecu harness wires clips and matched them up with a obd0-obd1 conversion chart off this guy that did the same with his home made chart on boosted.org just type that in google images and the chart should come up but thats how i put the obd1 harness wires to my ecu wires off the pr3 and now i dont know if its right and by the drivers shock tower theres a spider clip and 4 prong clip and byt the passengers side theres the distributor adn fuel injectors clips that obviously dont fit from obd to obd1, i google the plannet about this swap and aint got shyt for help, im sick of coming accross jumper harnesses for sale i dont give a shyt about buying some harness i know how to take the time to make it i just need the proper wire to pinout from th ePr3 ecu to the Obd1 po6 ecu please help!
