88 dx to MPFI???
Discussion in 'HYBRID -> ED-EF / DA' started by hatukazi, Jul 1, 2008.
  1. hatukazi
    hatukazi ambitious...but rubbish
    Big Lake, MN
    my buddy has my old 88 with a B18B and a super ghetto hacked MPFI job that used to run before the timing belt broke, the new timing belt is in and the engine has compression but wont run now.
    he just got married and will be in jail for a couple months so me and his brother think it would be real cool to get the car running for him while he's sitting, kind of a nice suprise for when he gets out.
    I have a 90 CRX Si engine harness and am wondering how hard it would be to change the harness plugs on the fender to mate up with the Si harness so it's not a ghetto job any more, I know there's a couple more wires in the Si harness and figure I can de-pin a few wires from a junkyard car to make up the difference, has anybody tried this before, I know the proper method is to modify the DPFI harness and use that but his is trashed and all the wires are red, it gives you a headache just looking at it.
    I have to re-attatch all the ECU plug wires anyway because they were cut, so since I have to do it the hard way I will need to use this method.
  2. fixed4 life
    fixed4 life New Member
    Haltom City TX
    I dont think there is a way to use just the Si harness you would have to change the harness that goes from inside the car to the engine compartment. To save you a headache go to the junk yard and pick up another dx harness you will also need an injector resistor box. I have done two of these swaps and its what i would do. Here is the link to where i got my info
    MPFI Swap
    Im sure if you search on this forum you will find write ups on this as well
    1 person likes this.
  3. efhondakid
    Akron-Canton, Ohio
    It wont work, the Si is a diffrent shaped plug than the DXs/HFs. Just re-wire in a better fashion.
  4. hatukazi
    Big Lake, MN
    shit, I was afraid it would be more headache than it's worth, when I bought it I didn't have time to look and see the 20 or so cut wires from the ECU (all red too), I suppose if I get the DX harness all the colors will line up anyway.
  5. monotech
    monotech Member
    Avoid the trouble and and just convert the Dx harness rather than changing out the cabin harness and engine harness. Save yourself the time and headache, Peace!
