cycloneb18c3
a kid i know did this with a 93 civic cx engine. Its a lot of fabrication(he built the go cart around the engine, and he got it running, but it cant get traction with go cart tires, he had to make custom axles for it to run 14 inch steelies. the thing is way too fast, and the steering is to "go cart ish" like turns way to fast when doing 50 and you lose control. its fun off road in the dirt. he has a APC muffler welded to the end of the header. it has a chipped P28 Ecu, the thing is crazy. has autometer tach, and speedometer. its like a mini car. he wants to put an old race seat in it now.
it is rwd, and yes it drifts. shifter is backwards.(1st is where reverse is, 2nd is 5th, and so on) has cable tranny mounted to it, for ease of running a cable, rather than hydrolic lines. He has a normal battery hooked up, and wires running every where. Im pretty sure he made his own harness.
if you have a lot of money to waste, go ahead and do it, its alot of fun doing all the fab work, and you really learn a lot.
