89hondahatch
Looking for some help from someone who has already tackled this combo: 1989 EF Hatch. Newly installed B20b (with Hasport mounts) attached to a 90-93 Integra LS "YS1" trans. I bolted on a "B" series mid-shaft that a friend had laying around (from a B-16, I think....) Purchased axles for a 90-93 Integra. They fit the trans perfectly, slid into my stock Civic hubs perfectly, and even fit the mid shaft perfectly.........When I tightened the spindle nut to the required 132 foot lbs. I reached up and tried to spin the tire/wheel and it was completly locked up...I had to back the nut almost all the way for the wheel to even spin. Where did I go wrong? Do I have to remove dust shields ? Is the mid-shaft the wrong one ? Do I need to change the hubs to those from a 90-93 Integra ? Thank you for any help you can offer.
