Help with auto cov into Ef plz answer
Discussion in 'HYBRID -> ED-EF / DA' started by cardinalboy07, Apr 28, 2013.
  1. cardinalboy07
    cardinalboy07 New Member
    Ok. Hg I got an auto b18a putting it into Ef
    I replaced flex plate with flywheel
    Got cable Ls, 5spd I. M. Ef b Series mounts
    Now the auto t bracket. Bolts up to 5spd trans all bolts went on, no misalignment .. Can I use that t bracket or no?
    Also since motor is auto can i still use auto half shaft and axles
  2. m90polk
    m90polk Member
    ri
    As far as the half shaft goes if it will fit into the transmission then it should work no problem but to be honest with you ive always seen them sold either for auto or manual im guessing it has to do with the spline count on the shaft.....so if u have the pieces just mock it up and see if they all go together and there is your answer.
  3. dilbeckskate
    dilbeckskate infamous
    Kennesaw Ga
  4. FLounder
    FLounder power hungry VIP
    north palm beach, FL
    i thought the auto and manual use different axles... but i could be wrong. like m90polk said, just try it and see.
  5. dilbeckskate
    Kennesaw Ga
    they use different axles yes
  6. jlicrx
    jlicrx Senior Member
    Colorado Springs
    the Integra axles are the same for manual and auto - the intermediate shafts may be different
  7. dilbeckskate
    Kennesaw Ga
    you are correct its the intermediate shaft thats different
  8. m90polk
    m90polk Member
    ri
    ^^^+1 Thats what i thought too
