90 crx wiring problems please help
Discussion in 'Civic and CRX - EF' started by d16z6si, Oct 2, 2009.
  1. d16z6si
    d16z6si New Member
    can anyone please help me i need to know where the wires go from the drivers side shock tower into the engine wiring harness the car has a d16a6 in it and the drivers side plug is the small 8 wire plug thank you to anyone who can help :eek:
  2. INJEN78
    INJEN78 HS LEGEND
    OHIO
    to a resisor box..
  3. jlicrx
    jlicrx Senior Member
    Colorado Springs
  4. d16z6si
    d16z6si New Member
    ok my injectors go straight to my ecu and the yellow black wire for the injector resistor is to the main relay if im worng where is the fast idle valve located
  5. d16z6si
    d16z6si New Member
    is that diagram for the small plug
  6. jlicrx
    Colorado Springs
    the diagram is for the Si/HF 8-wire connector at the driver's side - don't know what you mean by small plug - it is smaller than the DPFI 14 wire plug
  7. d16z6si
    d16z6si New Member
    ok i just wanted to make sure as i have 3 wiring harness for the car 1 is an si that i had to remake 1 is a jdm si harness and the other is a dpfi thats why i was asking
    what is the eacv and where is it located
  8. d16z6si
    d16z6si New Member
    and another thing is the tps sensor a 3 pin plug
  9. jlicrx
    Colorado Springs
    the Fast Idle Control Valve is only found on the 89-91 (not on 88) Si D16A6, on the back of the intake manifold
  10. d16z6si
    d16z6si New Member
    so on the d16a6 manifold it would be closer to the t/b right
  11. jlicrx
    Colorado Springs
    the TPS connector is a 3-wire connector with yellow/white, red/blue and green/white wires
  12. INJEN78
    INJEN78 HS LEGEND
    OHIO
    post a pic, of what your talking about...and yes tps is 3wire
  13. jlicrx
    Colorado Springs
    EACV, yes - to the right of the FICV in the picture - has 2-wire connector with blue/yellow and black/yellow wires
  14. d16z6si
    d16z6si New Member
    thank you for the diagram and the help with the other things
