91 civic dx d15b2 to d16y8 mount qeustion????
Discussion in 'HYBRID -> ED-EF / DA' started by bigwilly1878, Aug 13, 2006.
  1. bigwilly1878
    bigwilly1878 New Member
    ok on the driver side mount i cannot get my stock mount to line up with the bracket on the motor of the d16 i know it should work because its a d series motor, i just dont understand what the hell is wrong with it. has anyone ever dont this swap???
  2. 91CiVicSIhaTChVteC
    91CiVicSIhaTChVteC New Member
    it will not mount .............. if im not mistaken u can use the bracket off the y8 ........ or i have heard u can drill a hole right thru the middle of the bracket on ur hf
  3. bigwilly1878
    ok so i can take the bracket off of my d15 and put it on my d16 or drill my current motor mount?? is that what your saying????
  4. 91CiVicSIhaTChVteC
    take the bracket off ur d15 and put it on ur d16 .......... its the driver side motor mount bracket by the timing belt cover
  5. 91CiVicSIhaTChVteC
    thats what i did with my y8 swap
  6. bigwilly1878
    so basically take the timing cover off, and remove each bracket, then put the d15 bracket on the d16 motor? that makes sense if thats what your saying
  7. 91CiVicSIhaTChVteC
    exactly ............. take the bracket off ur d15 and put it on ur y8 and u should be str8........... lemme know how it comes out
  8. bigwilly1878
    ok, can you give me a walk through of how to replace the wheel studs, i broke one on mine now i have to put a new one in, and i just cant figure out how to get the things off
