91 lude si with b20a5
Discussion in 'Prelude' started by skrick, Oct 17, 2006.
  1. skrick
    skrick New Member
    Ok i have just gotten ahold of a 91 lude si and it needs a new engine because piston rods are bent and something with the valves is messed up... not sure what tho... so is it better to try and get a rebuild kit or find another engine for it... i haven't had much luck finding another b20a5 so i was wondering what else would fit in there easily... i'm not really lookin for HUGE power or anything i just need a good reliable car to drive... if there are other engines that would fit with the same motor mounts that'd be great and if you could tell me where to locate this engine that would also be fantastic... well thanks so much....
    tyler
  2. eludethis
    eludethis Junior Member
    check your PM box. hey you have a '91 Si? and it has a B20A5? hmmm...sounds like someone did a swap b4 cause you're supposed to have a B21A1.
  3. ride_hard12
    ride_hard12 Chris
    hmm....
    ya a 91 lude si doesnt have a b20 in it, im still looking for a jdm b20 if neone knows a place to get them that would be great, thanks!
  4. eludethis
    right now you'd be hard pressed to find a b20a. but if it helps any i got mine from nipponmotors. you can look them up on the web.
  5. Prelude4ws13
    Prelude4ws13 :::Trippy:::
    New York City
    Yes, it would be very hard to locate a JDM b20a, as they are becoming rarer and rarer. My friend tried for 3 months, and still no engine importer could locate one.
    My suggestion:
    Rebuild the b20a5.
    Get new valve train, springs etc. and with the block, send it out and get it overbored to fit b21a1 PK3 pistons. You will love the bump in power, compression and displacement.
    That, or get in on the h22 mount group buy at preludepower. Im in. You know it's gonna be all gravy next summer. ;)
  6. eludethis
    ^what's up i'm the 3rd person to send in the money order. H22 powwa baby.
