91 si hatch with 98 spec type R...transmission???
Discussion in 'HYBRID -> ED-EF / DA' started by vpower, Jul 26, 2010.
  1. vpower
    vpower New Member
    L.A.
    i am curious cuz i have a jdm b18c with a cable transmission and the car pulls hard and quick, but if i was to change the transmission to hydraulic will i get much more out of it...in other words is it worth the transmission to swap???and which is the correct transmission???
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    depends what trans are you running now
  3. vpower
    vpower New Member
    L.A.
    really have no clue just know its a cable tranny...how canci find out???or is that even possible???
  4. dateg513
    dateg513 New Member
    cincinnati
    there should be code on front lke ys1 , y80 biggest diff is wth hydro alot more options you can do lsd also hassport has a convo mount
  5. vpower
    vpower New Member
    L.A.
    well out of curiosity what kind of options would i het with a hydro tranny???and will it be a beneficial change for me???
  6. AHHVTEC
    Alabama
    well if you have a good cable trans i would just stay with that, its really not worth the money just for a little bit smother shift
  7. vpower
    vpower New Member
    L.A.
    well my tranny shifts really good...just had my 3rd and 5th gear synchros replaced and had hot flanked and the guy i took it to (he owns the shop i take it to) told me you now have a brand new transmission...but if its just for a smoother shift i think im kewl than...
  8. vpower
    vpower New Member
    L.A.
    another quick question i have a 9.75 lb flywheel???is that okay, or whatcha recommend???
  9. AHHVTEC
    Alabama
    depends on the type of driving you like, for me thats a good lb to go with not to lite
  10. vpower
    vpower New Member
    L.A.
  11. italian941
    italian941 New Member
    just found this web site and can't figure out how to post somthing can anyone help please and thanks
  12. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    There's some cable transmissions that have really nice gear ratios (mainly the JDM ones and the B17 GSR transmission). As stated before, only reason to go hydro is if you want to run aftermarket components; though I believe one of those cable transmission can use hydro parts(I'm not 100% on that so don't take my word for it).
    As for flywheel weight, 10-13lbs is ideal for DD and drag racing. Lighter is more suited for road course/autocross.
  13. vpower
    vpower New Member
    L.A.
    so im good then with the 9 pounder...thanx...
  14. vpower
    vpower New Member
    L.A.
    so whats the best tranny out there, or at least for my jdm b18c???
  15. 95EGCoupeVtec
    95EGCoupeVtec SOHC VTEC at its best
    South Mississippi
    the best would be a cable b16 tranny, it would have the shortest gears of the b series cable trannys. the best hydro tranny would be the ITR tranny. but it really depends on what you plan on doing to the engine. for boost, i'd recommend a hydro gsr or if you can get a cable gsr, stick with that. for all motor the ITR and b16 have the shortest gear ratios. only thing is that the 5th gear is pretty short, like 4500 rpm at 70-75.
  16. K2e2vin
    Raleigh, NC
    *cable B16 out of the JDM Integras and B17 Integras.
    ITR and hydro B16 have short gear spacing but the ITR is actually shorter due to the shorter FD. In other words, RPM drop is similar but with the B16 you'd spend more time in each gear and each gear would have a higher top speed for a given RPM.
    For boost though, the cable B16 would actually be nice. Has a taller FD(4.266 or something around there) but still has short RPM drops. As for what's the best; really depends on what you're looking for. For me, DD with a short transmission is pretty annoying.
  17. vpower
    vpower New Member
    L.A.
    well i have a s1 transmission???any help???
  18. K2e2vin
    Raleigh, NC
    Most likely a "LS".
  19. vpower
    vpower New Member
    L.A.
    is that good???
  20. K2e2vin
    Raleigh, NC
    That's the tallest transmission I believe, good for daily driving and I guess high-power turbo setups.
