91EX with a vtec head HELP!!!
Discussion in 'Accord' started by 91stockEX, Sep 26, 2006.
  1. 91stockEX
    91stockEX New Member
    Im new to hondaswap but i got a 1991 honda ex with a stock f22 SOHC and i was wondering if i could put on a VTEC DOHC and switch out the ecu if it would work, what type of head can fit on it ?
  2. F22HB
    F22HB New Member
    It seems pretty doubtfull but if you find out that you can, send me a pm cuz that'd be sick!
  3. fastacc
    fastacc Doin work!!!
    TX
    As I understand it you can use an h22 head on the F motor. I have also heard that the F bottom end is a little weaker than the H.
  4. d112crzy
    d112crzy im not a n0ob, trust me
    you CAN swap the h22 head on there, its just a bit of work.
    heres a thread on f22b2 with h22 head. its pretty much the same thing, the block might be a little differnt, but nothing big.
    Honda-Tech.com: F22b2 block+H22a1 head, F22 VTEC, F22B/VTEC
    f22 block is stronger, but it really depends on what you mean. f22 sleeves are good for boost, as opposed to h22 sleeves.
    if you plan on doing this, i suggest you dont rev the piss out of the f22 block, unless you some crank work. installing some oil squirters would be a very wise decision.
  5. RY2K
    RY2K New Member
    Long Island, NY
    yes you can put a f22 vtec head on it, i need to get info
    unless you want to do a search on honda-acura.net
    some one did it, but it might not be worth it for you
    if you can just swap in a long block from a 5th gen accord
    or go for the h22, or get an older non vtec h22 out of an older prelude
  6. d112crzy
    theres no such thing as a non vtec h22.
    preludes had an f22a1 sohc, dohc h23 non vtec, or an h22 vtec. get it right, i hate it when people spread false information on the internet.
    and if you knew how to read, he asked about the h22 dohc vtec head, not an f22 sohc vtec,which would be totally pointless.
  7. phunky.buddha
    Dallas / Fort Worth, TX
    Calm down guys... no fighting.
  8. RY2K
    RY2K New Member
    Long Island, NY
    it's all good i miss read
    no need to get so angry
    excuse me for not being such a honda geek
