Asking 5000$ or best offer Or Parting out. The car is worth more then 5000$ Just in parts . I just moved, the car needs to go. - black 92 sedan needs body work end of story! - windows and moon roof are functional - D15B with 40,000 - 50,000 miles and stock internals runs great. - sony cdplayer, 4 very nice polk momo speakers, stock and fairly clean. - short shift - apc - hks high power cat back system - onmi power camber +/- 4deg. front and rear - kyb agx 4 way adjustible shocks - tanabe sustec df210 2" drop springs - stainless steal break lines - tpr junk cross drilled and slotted rotors - axxis ceramic / metallic pads - 15" no name junk rims - 4 toyo proxes 4 ( some early camber wear ) - rebuilt manual stearing rack - new inner, outer tie rods, ball joints etc. - abs has been removed. - full set of energy suspension bushing Fidanza 7lb flywheel Spec stage 3 clutch ( 2 clutch disks ) Golden eagle vaccum manifold Walboro fuel pump 255cc Greddy boost controler Greddy turbo timer Stock Obd-1 Ecu AEM EMS 30-1000 Front mount Intercooler 3.5" x 6.5" x 27 "2.5" Inlet / Outlet Tial Wastegate 35mm Tial Blow Off Valve 50mm AEM map sensor ( Never Wired ) AEM fuel rail AEM fuel regulator AEM fuel filter B&M fuel pressure guage RC 550cc Fuel Injectors ( Never Used ) Rank 1 Turno manifold w/ wastegate flange Garrett t3/t4 Unorthodox adjustible cam gear +/- 10deg. Unorthodox crank shaft pully There is more i am sure. Not On The Car Seperate Sale: - Scat Mfg. H-Beam Rods - Crower stage 2 cam shaft with Crower springs and retainers - Crower titanium keepers - Ferera Intake and Exaust valves - Race Port & Polished Head needs resurfacing in cylinder 1 Everything listed above for 500$ it also includes the head and block
HOW MUCH 4 ALL OF THIS - Scat Mfg. H-Beam Rods - Crower stage 2 cam shaft with Crower springs and retainers - Crower titanium keepers - Ferera Intake and Exaust valves - Race Port & Polished Head needs resurfacing in cylinder 1
