94 EG: LS swap keeps stalling...
Discussion in 'Civic and del Sol - EG and EK' started by danny94eg, Feb 2, 2010.
  1. danny94eg
    danny94eg New Member
    whats up guys!!!
    i got a 94 civic hatch eg w/ b18a1 swap and b16trans. pr4-ecu
    i recently did the swap and when i try 2 start the car it cranks but immediately stalls...
    if i hold the gas pedal down i can hold the rpm's steady, then AFTER the car warms up completely the car can hold idle and drives fine... i think the problem has something 2 do with my IACV but i tried changing it out with another IACV but still stalls...
    all help is appreciated!! thnx!
  2. danny94eg
    anyone???
  3. phunky.buddha
    Dallas / Fort Worth, TX
  4. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    What about the injectors, dizzy and alternator? Are they B18A1 (OBD0) or did you make sure you put B18B1 stuff in it? I woudl also suggest a B18B1 ECU too. There's ways to rig it to work with OBD0 but I truly feel its a bad option and only used for those who truly can't afford making it work and must have a cr to dirve immediately.
  5. danny94eg
    yea those parts i think are ok.. i actually pulled this motor out of a dc integra that was running obd2... so i spliced the dizzy back to obd1, and re-used my sohc vtec wire harness.
  6. danny94eg
    does anybody kno if a D-series throttle body can fit on a b18a/b intake manifold???? i think the problem with my car stalling is, currently, the t-body on my b-series mani doesnt have a FITV(fast idle thermo valve), so i was thinking about just switchin'em out??? the d-series t-body is from d16z6
    thnx
