94 integra clutch problem??? Help!!!
Discussion in 'HYBRID -> EG-EK / DC' started by civicracer10, Apr 21, 2009.
  1. civicracer10
    civicracer10 New Member
    philly
    I have a 1994 acura integra ls coupe with manual transmission.
    I've already tried to research online and cant find and answer.:confused::confused:
    My problem is that sometimes i cant get it to go in any gear, and it grinds real bad.
    sometimes i need to turn the car off then put it in gear then start it again, other times i start it and it works fine all day.
    what could be the problem??
    slave cylinder???
    any help is apperciated
  2. get_nick
    Washington State
    syncros are shot. needs a new tranny or a rebuild.
  3. civicracer10
    philly
    also
    whats the best tranny and clutch for my 94 integra?
    its got dc headers, dc cat back exhaust, msd blaster coil ignition, injen short ram intake.
    should i just get the oem clutch or go stage 1 or 2???
    and what are the advantages over oem?
    thanks alot
  4. civicracer10
    philly
    so the syncros will work perfectly sometimes then other times not work at all???
    because like i said sometimes it shifts perfectly then other times i cant get it in first without shutting it off then putting it in gear then starting
  5. get_nick
    Washington State
    i would just get an exedy stage 2. i had one and it drives like oem but it grabs a little better.
    if you can afford it get an ITR tranny for the lsd, otherwise a GSR tranny would be good.
    think of how a tranny and clutch work. try to conceptualize what the process is and what would make it do that.
    if you engage the clutch, but you can't shift, the syncros are broken or out of sync. it's not allowing you to shift.
  6. civicracer10
    philly
    is there any way to make it last another week or 2 because im gonna buy another tranny in a week or 2, but i need to drive it every day, and if i cant get it in gear sometimes its a pain in the ass.
  7. civicracer10
    philly
    thats what i was thinking about buying a gsr tranny but someone told me the b16 tranny is better
  8. get_nick
    Washington State
    the only one that is "better" is the ITR because it has an lsd.
    it all depends on what you want to do. if you want short gearing for a 1/4 mile, get a b16 tranny. if you want better mpg, get an ls tranny. if you want something in between get a gsr.
    the word "better" is a matter of opinion.
  9. civicracer10
    philly
    i had just seen online if i put gm syncromesh in the tranny it might help??
    anyone know anything about that??
    and thanks alot for the help guys im pretty new to this all.
  10. get_nick
    Washington State
    please post the link that you read that.
  11. civicracer10
    philly
    thanks i think you just sold me on the gsr tranny
  12. civicracer10
    philly
    Have you tried Synchromesh yet? I would try that before buying a new tranny. I prefer the Pennzoil variant, the Royal Purple didn't stop the synchro-gring as well....
    thats what they said on superhonda.com
  13. Fernpatch
    Fernpatch Member
    Bellingham,WA
    Before you get carried away with a new transmission double check your clutch hydraulics. If you can have a friend push on the clutch pedal when its acting up and watch how much or little the slave cylinder is moving the release arm. From what your describing I strongly suspect your clutch master or slave cylinder is starting to bypass internally. have you observed any change in the fluid level? try peeling back the rubber boot on the slave cylinder and check if its wet inside. good luck.
  14. crvtt96
    crvtt96 Junior Member
    chi-town
    Yes, Fernpatch is right! It sure sounds like a clucth hydraulic problem. You could change the trans and still have the same problem.
