95 civic dx swap, need help
mrather
My 95 civic dx came with a d15b7 engine. I have installed a 1996 d16y5 vtec e.
What changes to wiring and or computer will i need to make. The car is a
5-speed. I know that i am putting an obd2 into obd1 car. Any help would
be appreciated. thanks
well, you should be ok using your stock computer, you just need to wire up the vtec, changing over to obd2 might involve a lot of work.
Use the B7 injectors,distributor and alternator on the Y5.
Add wires for VTEC and whatever else you need.
If you want vtec to work, then you can't use the d15b7's ecu, unless you do a vtec conversion on it. See www.xenocron.com for this kit.
