i have a working d16z6 swap the prevouis owners did. looked at every post on here and i know i'll need to change the Distributor and fuel injectors. but my questions are
1. Can i use the harness i have now??
2. Can i use the D16Z6 injectors?? If not which engine should i get them from??
3. Can i use my existing motor mounts??
4. Can i use the axles from an LS??
Thank You in advance
