maxbodyworks
maxbodyworks
Ok I have a 97'GSR,.. previous owner had swapped a B16a2 into it which is a raging mother fucker for sure,... nevertheless ended up spinning a bearing,...and have decided in order to meet emissions and bring the power up substantially, that it was going to be necessary to go back stock (b18c1),..and found that motor is very expensive and rare these days,... So I am leaning towards building a B20,...what do you guys think,.. any suggestions,... I dont have tons of money to blow ,.. I have tons of experience ,..My questions are as follows
----What is the best motor to put in here?
----Will my rebuilt head off the B16a2 work on a B20?
----Will the Cams off the B16a2 work on a B20?
----will the Gsr Transmission work?
-----If I do the B20,.. I plan on replacing pistons, rods, bearings, and bolts, balancing of the lower end, and the vtec .
I think thats it If you guys have anything else of severe importance that I need to be thinking about , your input will be greatly appreciated.
MAX
MAX
