98 civic lx revs to about 2000 rpms then drops back down
Discussion in 'Civic and del Sol - EG and EK' started by bwerth, Aug 21, 2012.
  1. bwerth
    bwerth New Member
    98 civic lx revs to about 2000 rpms then drops back down then back up again and well you get the point. Then after i drive it somewhere and shut it off it don't want to start and I have to hold the gas petal to the floor and crank it and it will slowly get runnung again for a little bit. Driving down the road I make it less than a ,ile down the road and she stalls again. So I start her the same way and she will finally make it home. I have replaced the timing belt, the distributor, the Idle air control valve, about to do the Throttle positioning sensor next.
    So 2 questions on this, first, am I doing the right things so far and second, How can I fix my car and have her running like new again.
  2. tabKola
    tabKola New Member
    Tewksbury MA
    If the idle is fluctuating, then you most likely have a vacuum leak. Is it throwing any codes?
  3. bwerth
    bwerth New Member
    I am taking it to Advance Auto tomorrow to have them pull up the codes. I will put them up here as soon as I get them.
  4. bwerth
    bwerth New Member
    P0505
    Idle air control system
    P0301
    Cyl.1 Misfire
    P0302
    Cyl.2 Misfire
    P0303
    Cyl.3 Misfire
    P0304
    Cyl.4 Misfire
    P0300
    Random multi cyl. misfore
    P1399
    Misfire in any cyl.
    Just had a new add on too. When I changed the idle air control valve there was anti freeze in the line and I am guessing it wasn't supposed to be there because I am pretty sure that is a vacuum line.
  5. rayfmx427
    rayfmx427 New Member
    hve you checked the head gasket i had this problem in a 95 civic and my friend had this problem when his rings went have you done a oil pressure test and checked that the cylanders werent holding pressure from the bottom end?
  6. bwerth
    bwerth New Member
    Being a disabled vet I have to wait until the first to get paid so I can tke it in to have it tested. I am just trying to see what it could be to see if its something I can fix. Last time I checked before timing belt was replaced they told me that the head gasket was good.
  7. BrutalB83
    Rochester Hills, MI
  8. serrilion
    serrilion In my own little world! VIP
    Vermont
    A head gasket wouldn't do this there would be other issues such as oil in coolant visa versa... Sounds to me like you may have a bad trotle body gasket or not tightened up all the way, also if you didn't replace the gaskets when u replaced the parts air could be sneaking passed the old worn out gasket and causing this issue, I would check them... maybe use some sylicone gasket to see if it fixes it... just some ideas
  9. bwerth
    bwerth New Member
    I was going through the chiltons book I have and it shows that coolant does pass through the idle air control valve, so I was wrong about that one. I went to put anti freeze in the reservoire recovery tank and noticed there is oil in there so guess that confirms at least a head gasket issue. The thing I am wondering is, if I put the distributor on incorrectly could it cause the running issues or would it not start if it was on wrong or in the improper position.
  10. serrilion
    Vermont
    A wrong dizzy would ether not start the car or it would and run like crap... You could check the timing, tho if you have a head gasket issue its not worth checking timing just replace the head gasket and then reset ya timing once u reinstall the head and T belt
