i have a few questions... 1.if i want to run 12 psi daily, and run a high of around 20 psi on a track day,what size spring for the wastegate? 1.5 bar good for 21.xx psi but can you also have that spring for 12 psi?? 2.do all size wastegates fit on the lovefab sst mani?(40mm) 3.will the 50mm tial bov be good?
the spring in the wastegate is the LOWEST you can go. bosot controllers can only RAISE you from your base spring. .7 bar (11 pis ish) is probably what you want. no, you will need a tial 40mm wastegate others won't fit. 40's are 4-bolt, 35mm are 2-bolt, 46s are huge. good, its great. sounds awesome, and does the job
