A real transmission swap question
Discussion in 'HYBRID -> EG-EK / DC' started by SlushboxTeggy, Oct 18, 2007.
  1. SlushboxTeggy
    NJ to MA to CA
    Since I stopped drinking I have a lot more income just lying around. So what to do? FINALLY swap the tranny on the teg. So here's the question... I want to use a cable tranny. I'm getting a YS1 from jjrjdm85. The motor(boost ready LS-V) I'm getting from jjrjdm85 is also OBD1. Could I take a 93 Integra (cable and OBD1), use it as a parts car, and use all the stuff out of that to swap the tranny on the 97 and make it OBD1 with little or no modification?
    I'm simply asking because it would seem that getting everything all at once would be more cost effective and having two extra LS motors laying around is never a bad thing.
  2. eg6sir
    why are you going cable??
  3. Hasid Lafre
    Hasid Lafre Master of the obvious
    Why use a hydro trans?
  4. SlushboxTeggy
    NJ to MA to CA
    I've been told that it's a little harder to swap to hydro from auto, plus a good hydro tranny is $$$. Not to mention I've always preferred the feel of cable (It may be mental, but I swear I feel a difference).
    Sooooooooooo, will a 93 parts car work the way I think it should?
  5. SlushboxTeggy
    NJ to MA to CA
  6. SlushboxTeggy
    NJ to MA to CA
    Yup again, I need this info guys. I need something to occupy my mind for a few months.
  7. SlushboxTeggy
    NJ to MA to CA
    Yup again. I know someone knows if the stuff is compatible.
  8. reikoshea
    Dallas, TX
    Im not 100% certain, but im pretty sure you are on the right track. There were very few changes made to the integra over the years (body structure wise), so if you have a 93 parts car you should be able to move all the shit into the 97. The only questions would be sensors, but if the 97 is already wired as an OBD1 you should be okay.
  9. SlushboxTeggy
    NJ to MA to CA
    Its not, but I would have to do it even if the tranny wasnt cable.
