Adjust clutch
MaxThruster
My 94 civic ex grinds when shifting into reverse. Other posts say to adjust the free play on the cable nut. I have a Chilton's guide, but it only shows it for older models without the threaded bolt that I have. Which way do I turn it to tighten the clutch up a bit so that it can fully engage? Thanks.
under the dashboard, on top of the clutch pedal.
there is a threaded bolt. give that a shot.
otherwise, bleed the clutch system ;)
Clutch Nut
I meant the nut that was under the hood on the transmission at the other end of the cable. Can that one be adjusted to shorted the cable length?
