love the thread bro. im actually running the same set up on my z6 so i cant wait to see that thing run!
You mean does it leak? If I had to guess, it's going to leak like a sieve at the mating point where it meets my exhaust.wikedeye said:Does the flex pipe hold pressure or will you find out tomorrow? Congrats on the last class.
Effective Compression ratio is always going to be higher than Static. A 9:1 comp engine pushing 10 psi is at 15:1 effective.
It doesnt mean you can't run boost just because it's high, you just need to have a rock solid tune.
Lotus is coming out with a turbo engine for one of their new cars w/ 11.5:1 compression boosting 5-6 psi. imagine what the Effective compression ratio is for that! not to mention it's going to be in europe, with mucho hills and higher altitude in general.
The altitude wasn't what I was talking about. I was pointing out that you're going to be running pretty high effective compression, so your tune needs to be really good.
What kind of power are you making?
Great! Thanks man!
I'm getting ready to drop $500... $220 shipped o the WideBand (AEM UEGO) and $284 shipped on the ETD Traction bar. Ugh.
It's necessary, but dang. I hate doing this. especially when I want to buy a new car soon.. geez.
Dude, I made (3) 3/16 spacers for you today. They match nearly perfect to the oil return. MUCH better than what you have now, plus they are flat I'll give em to Meglet so you can have em tomorrow
His oil return was a lil short and it kinked the line if he mated the flange to the turbo, she he needed a couple of spacers to get rid of the kink.
ANd did you talk to Max about the AEM? Is that what he suggested?
seller said:the actual head casting is new , i reused rocker arms but had them all checked out before i reused them , everything is in good shape , has the stock cam and cam gear included ,
I found a good deal on Craigslist for a 'new' D16Z6 head for $200. Should I jump on it?
2004 Accord K24A4 2.4 litre with 29k miles and a 2002 RSX type S 6-speed tranny with 42k miles. 1700.00 OBO
