another ??? for air fuel guage needing quick responce
Discussion in 'Civic and CRX - EF' started by crazymark01, Jul 12, 2007.
  1. crazymark01
    crazymark01 New Member
    what wire do i splice the purple wire on the guage so that i can get a good reading for the air/fuel guage??? any quick responces would be great im installing it as i type. thanks
  2. humblegumbo
    humblegumbo 1595cc's of Mad Fury
    CA
    If you haven't already figured it out for yourself... more information is really required for anyone else to answer your question.
    It could be for power or signal depending on the make.
    Also, it would probably be way faster for you to search Google yourself.
  3. eg6sir
    in order to get a good reading you'll need a wideband O2
  4. Turbo&Auto
    Turbo&Auto Nick Go FAST!!
    East Burg, PA!
    It should be the white or blue wire on the O2 sensor. If you goto plxdevices.com they have ECU pinouts for some Honda's, you can find the exact wire you need and tap into it inside the car :)
  5. crazymark01
    sorry i have a 89 crx si with the d16a6 motor in it.
  6. humblegumbo
    CA
    What kind of air/fuel gauge?
  7. Turbo&Auto
    East Burg, PA!
    sounds like autometer, they have a purple signal wire :)
    Edit: I cant find a pinout for that old of a car :lol: Worse comes to worse you can run a wire out into the engine bay and tap into the O2 right at the O2. Check the white or blue wire with an ohmeter, it should be around .5v with the car idling. It will also toggle between 0 and .5 or higher.
  8. crazymark01
  9. humblegumbo
    CA
    So there should be three wires to hook up.
    Red = Power
    Black = Ground
    Purple = O2 Signal
    The wire from my O2 sensor is blue...very easy to find because there is only one wire coming out of the sensor. Where it goes from there, I'm not 100% sure, but you could trace it.
    Edit:
    Found wiring diagram for d16a6 ECU.
    http://www.autozone.com/images/cds/gif/large/0900823d80141ec1.gif
    Looks like O2 sensor goes in at C16.
  10. jlicrx
    jlicrx Senior Member
    Colorado Springs
    on the D16A6 engine, the OEM O2 sensor has a black wire which plugs into a connector down by the transmission - from that connector to the ECU, the wire is a shielded, is white in color and goes to ECU pin C16
